Turn signals
Turn signals
Ok folks, I replaced my rear lights and parking front lights with LED and replaced the turn signal lights on the dash but now my turn signals don't work properly they light but don't turn off and on. What I am missing, here?
Cheers
Paddy
Cheers
Paddy
If I recall....you have to replace the flasher module for them to work but they should provide one with the kit.
If they still aren't working, check your grounds. You have to ground the flasher they provide under the dash.
Mine didn't work right at first but I had the ground wires in the trunk bolted to the wrong spot.
Unfortunatly mine from NPD did not come with a new flasher module, so I am assuming I need a special one for LED's is this true and were can I get one, please bear in mind I live in europe, so need mail order or scott drake product.
Cheers
Cheers
http://www.mustangproject.com/Produc...5-a4c64fe01e4e
This will probably work....order two because you will also need a second one for you emergency flashers.
Mustang project says they ship world wide so being across the pond shouldn't be an issue outside of add'l shipping costs.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
