Powder Coating ?
It is usually referred to as ceramic coating and it will last a long time, unless you use them for engine break-in with a flat tappet cam. That will burn the coating right off. Installed after break-in and they look great.
I had mine done probably 9 years ago and they still look great.
http://www.putfile.com/pic/4991980?pos=top
very nice
I would only make sure you shop around because Ceramic Coated headers can range from $350 - $900 bucks.
pro - keeps your engine bay a lot lot cooler and as a result your water temp and your inside temp. you can do old headers provided they are in good condition (structurally not visuallly) and the process will extend their life. You must do inside and outside for full benefit.
cons - cost and con artists! I've seen dyno results showing a very slight drop in performance and ive yet to see any results showing the increases which some suppliers claim. Not to say it aint so, just not evidenced.
we did a set on a race car 2 years ago. no noticeable change in power. massive difference to floor temp (no longer burning the soles of my feet) and big drop in engine operating temp between stages from around 195 to 180 with no other changes.
