1967 power steering problem...
..just wanted to say hello... I've been reading posts for a while on this site and everything has been really helpful.
i have a 67 mustang coupe, 289 with a power steering problem. It has the original power steering rack but a newer style power steering pump - I think it came off a late model 302 mustang setup. Anyways, while going slow and making turns to the left or right the power steering screeches almost as if something is binding up causing the belt to slip. I'll be taking a look at the belt tomorrow to determine if the tension is correct or it needs replacing. However, the steering components are old, so I'm sure there something is binding up. Is there any recommended additive for power steering that will help reduce binding? What other causes could there be for this binding?
Thanks
Thanks
A) There is no power steering 'rack' in your car, unless someone converted it. It should have a power assist ram hooked to a normal parallelogram steering linkage.
2) Either the power steering pump is making noise, or the belt's slipping. Pump noise will sound more like a loud, really fast ticking sound, or like a squeaky rubber bushing. A slipping belt will be a high pitched squeal. If the belt's slipping it likely needs to be tightened or replaced. If your pump is actually making noise, try flushing it out with some Seafoam Trans-Tune, then fill it back up and see how it works.
Thanks
Thanks
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
