Automatic Transmition Question (c4)
I purchased a new pan from summit to replace my stock one. When looking I found some pans were for 70's and up. I was under the impression that a stock ford pan was good from 1965-1973. Is this not right? Will the new pan work?
Also When it comes to fluid, is it ok to use Original Trick Shift ATF vrs the synthetic?
This is what I bought:
http://store.summitracing.com/partde...5&autoview=sku
Here is a picture of my old pan and transmission
When refilling its 5 1/2 qts of fluid, right?
Will this fluid meet or exceed Mercon or Dexron III requirements
http://www.bmracing.com/PRODUCTS/Flu...12-qt-box-ONLY
the diff is the case dip stick tube vs the pan dip stick tube. this looks like the correct one for you. Did the unit recommend a filter extension? Some deep pans require an extension to lower the filter further into the pan.
im sure that fluid will exceed those requirements, but your car doesnt use those
a c4 tranny in a classic mustang uses Type F transmission fluid
Acccording to the pan specs it's the same capacity.I would drain the converter to when you change it and it should hold between 8 & 9 quarts. Unless your trans has been rebuilt and had different frictions installed like rmodel65 said it should take type F.
I let it drain over night and about an extra qt 1/2 fell. Im going to give it another 8 hours before the fill. I cant believe how much fluid was still in there after the initial pan drop.
hmmm, I was under the impression that type F was for in the '70s. Type F was the Ford specification for auto trans fluid prior to 1977. Beginning in '77, Ford began specifying Mercon fluid in most transmissions, and in all by '81.
I thought Mercon fluid far surpassed type F, that is why type F is nearly impossible to find at the auto part stores.
LivingInThePast
09-16-2015 12:20 PM
dalefrancis88
09-11-2015 07:15 AM
09-08-2015 11:50 AM
