Just bought my 65! Question on a sound
Hi Everyone,
I'm glad to say I just picked up a 65 Mustang tonight!!! I traded my 96 Dodge Ram 1500 pickup for this Mustang even. The Mustang has a straight six/auto in it and runs very well.
While driving it home I began to hear a repeating noise from one of the right side wheels. Almost like a flapping sound as the tire went around. When I pushed on the brakes it goes away. And I don't mean the sound stops when the car stops with the brakes. I mean it stops making that noise while the car is driving and the brakes are pressed some. I know its hard for anyone to identify the noise just by this description but figured I would ask anyways.
I've got a few things to do to the car. When I need to stop, I have to pump the brake pedal atleast once to get a good stop. Gotta love those drum brakes!! No heat in the car so I'm eventually going to add one of those heat/ac units in 3-4 months.
I'll post pictures of the car tomorrow.
Thanks!!
Warren
Thanks!!
Warren
welcome
you shouldnt have to pump the brake to get it to stop just coz they are drums. if they are working properly the stopping ability is just as good as discs for the same size (ie what will fit under 14" rims). the big difference is that the discs cool more efficiently so you'll get more repeated stops before they start to fade.
when you get a chance, pull the wheels and take the drums off. whatever is flapping around may be obvious.
good luck.
good luck.
Well, you can be almost certain it is brake related. It sounds like you have some air in the lines as you shouldn't have to pump them to get a firm pedal. It is a good idea to change the brake fluid anyway, so do that and bleed them and you will probably get a firm pedal back.
check on the brake hoses on the front. mayeb you have something hitting it while you drive causing this flapping sound. PLEASE do check on what causes the sound before you drive any further, it might be well dangerous.
Maybe jack up the car on that side and turn the wheel manually see if you can locate what's causing it.
Then make sure to bleed the whole brake system (replace not only bleed) as that mightn't have been done for several years turning your brakefluid into useless crap
reason I'm saying this is that most of the 65 models have a single circuit master brake. If one brake goes (looses pressure) all brakes go. there is no more stopping the car then
haha if their bias if it was sitting awhile ull get this sound which sounds like what is going on since it happens when your driving the whole time wheel bearings are normally when your taking a corner
