where to find engine info on the block
Old 02-24-2009, 10:43 PM
az1966
az1966's Avatar
Default where to find engine info on the block
1966 mustang ,,,200ci engine cali smog, 3 spd tranny, no ac ,,,issue is that my engine needs rebuilding and when I pulled the head to have it rebuilt,, me and a friend noticed a "hair line crack" in the #1 cylinder and the compression checks done before indicated something was wrong,,, and losing water/antifreeze
question is can a good shop "fix" this during a rebuild or do I need another block,, and if so where can I find the "born on dates" to pre find one to cover the bases
thanks for any help info
az1966 is offline
Old 02-24-2009, 11:05 PM
Stangman70
Stangman70's Avatar
Your best bet is to find another block. If your # 1 cylinder has a crack the likely hood of having a shop fix it correctly, and cost effectively, are slim. Finding a block may take some time, but not impossible. Inline 6's aren't as plenty as they used to be but, your local junk yard may hold something special.
Stangman70 is offline
Old 02-25-2009, 07:44 AM
Gary H
Gary H's Avatar
They should be able to sleeve it. It's not that expensive. Call a few machine shops and ask.
Gary H is offline
Old 02-25-2009, 08:23 AM
my77stang
my77stang's Avatar
yeah, sleeving can fix the block pretty easily - of course you'll be needing to bore the cylinders after that and get new oversized pistons. The reason is that when they press the sleeve into the cracked cylinder it will distort the cylinder next to it which requires that cylinder to be honed. once they do that your left with a cylinder that is out of spec, so boring it out is the way to go.
this may be a good opportunity to upgrade to a 250 and pick up a little power.
my77stang is offline
Old 02-27-2009, 12:45 AM
az1966
az1966's Avatar
I want to keep the block within the cars manufacturing date, and not to hot on over boring if I can help it,,I had heard there's manufacturing dates on the block, and as I said want to try to keep as original as possible
az1966 is offline
Old 02-27-2009, 08:22 PM
Gary H
Gary H's Avatar
Odds are that if the engine has never been rebuilt then it will need to be bored out anyway.
Gary H is offline
drfister
05-03-2018 10:38 PM
Gary Ugarek
08-26-2015 08:41 AM
dba Brakes
08-21-2015 07:07 PM
kirk35
08-17-2015 08:42 PM
Quick Reply: where to find engine info on the block
