Oil pressure
Oil pressure
I went for a drive today in my '66 coupe and i noticed the following:
When the engine is cold i see the oil pressure gauge inclining to the middle of L and H, but when i drive the car for 10 minutes i notice that the oil pressure needle goes down again (back to L). So I am guessing i am having a loss of oil pressure somehere.
What are the most common reasons for this to happen ? Or is this normal ?
I would guess my oil pump is malfunctioning... correct ?
RE: Oil pressure
Michael, the gauges on these old cars are bad at best. If you don't hear a ticking from your engine, then your oil pressure is just fine. If you have any reading at all at the oil pressure gauge, then your pump is working. Relax.
RE: Oil pressure
Well i do hear it ticking sometimes after i turn the engine off. The radiator is also making some noise.
I thought it was normal for an engine when it cools down ...
RE: Oil pressure
To be safe you may want to get an aftermarket oil pressure gauge, It could be mains, cam bearings, or something else... Oil thins out as it gets warmer, doesn't it? I noticed on my Durango that the needle will be as high as it can go (opening the pressure relief valve on the oil pump) when it's cold, or has new oil in it, but then after it gets warmed up it tends to be at about 1/3 the way through.
ccdguy
09-19-2015 05:20 PM
