Really screwed myself out of wheel choices
Old 03-01-2009, 11:32 AM
stangtjk
stangtjk's Avatar
Default Really screwed myself out of wheel choices
I'm using the front and rear suspension from a mark VIII and cant find any rims I like that will work. The wheels from the mark VIII are 16"x7" with a 39mm offset and the tires are 225/60/R16. The rear fits fine but the front is about a half inch too wide. I'm either going to have to flare the fenders a little, run a larger offset wheel or use narrower tires or maybe a combination of the three. Has anyone seen a good looking high offset rim that doesn't look like it belongs on a tuner. I'm looking for 17s or 18s and can run a max backspacing of around 6.25". I'm guessing I'd need something like a 18x8 with a 45mm backspacing.
stangtjk is offline
Old 03-01-2009, 11:42 AM
Starfury
Starfury's Avatar
FR500's always look nice What color is the car, again?
Starfury is offline
Old 03-01-2009, 11:45 AM
stangtjk
stangtjk's Avatar
Its gonna be black its just in primer at the moment. Can you get the FR500 in an 8" rim all I've seen is 9s and up. I don't think they will have a large enough offset either.
stangtjk is offline
1slow67
ROTM Moderator
1slow67's Avatar
I want my 67 looking similar to this:
1slow67 is offline
Old 03-01-2009, 11:53 AM
stangtjk
stangtjk's Avatar
Mine might have to look like that to get a set of rims on it that I like lol.
stangtjk is offline
Old 03-01-2009, 11:54 AM
Starfury
Starfury's Avatar
A guy on another forum just put some Budnik GTX's on his fastback. I was skeptical before I saw them mounted, but they look awesome on the car.
Starfury is offline
Old 03-01-2009, 12:08 PM
1slow67
ROTM Moderator
1slow67's Avatar
I looked and only saw 9" and up.
1slow67 is offline
Old 03-01-2009, 01:18 PM
nba1341
nba1341's Avatar
american racing ones
nba1341 is offline
Old 03-01-2009, 02:30 PM
stangtjk
stangtjk's Avatar
I forgot to mention the bolt pattern is 5x108 (5x4.25). I can swap the front hubs with ones from a mustang and redrill the rear hubs to convert to 5x4.5 depending on what wheels I find.
stangtjk is offline
Old 03-01-2009, 02:39 PM
stangtjk
stangtjk's Avatar
These are the only ones I found so far that are the correct dimensions. They are 18x8 with a 45mm backspacing and a 5x114.3 (5x4.5) bolt pattern. I'm not sure if i like them but they may look good on a black car.
I like these a little better they have the 5x108 bolt pattern but a slightly less offset (40mm).
What are your opinions on them.
stangtjk is offline
Quick Reply: Really screwed myself out of wheel choices
