How many square feet?
How many square feet would you say is the floor pan and toe boards/firewall are? Hopefully next weekend I will be replacing my passenger toe board and front floor pan and I figure it would be a good time to seal it and put some sound deadener and modern insulation down.
I bought 160 sq/ft of SecondSkin Dampilfier Pro and from the top of the firewall down, across the floor, up the trunk divider (welded in plate now), roof, trunk side of the divider, trunk floors, top of rear wheel wells got covered. I also used a lot of the scrape for inside the B-pillars, doors, inside the dash and hard ro reach places on the quarters. I have 1 of 5 boxes left over for doubling up in a few areas. Knock the front fenders and you get the typical 'tinny' sound but everywhere else its a very solid thump. Trunk, undercarage (POR-15ed right now), inside floor, fenders and inside all 4 wheel wells will be hit with the SecondSkin Spectrum product as well.
If you really want a difference I'd suggest getting 150 sq/ft of whatever you use. I didn't overlap except in a few areas and will use all 160 that I got. It really makes a huge difference!
I'm not so much concerned with the noise, I actually like the noise and being able to hear my engine. I was mostly looking to put some insulation between me and the engine and trans other than just the sheet metal, there is none, the heat can get bad even on cool days. If it reduces some road noise great but I will redo it when I repaint the car down the road for everything, I'm just looking to make it a little more enjoyable to drive. I plan on getting a roll of RAAMmat BXT right now and when the full resto is due upgrade to Second Skin.
Thanks for the tips guys.
well it worked and it quieted the sound a lot also but if the windows are down you still get to enjoy the exhaust
