1966 mustang
Old 03-08-2009, 06:08 PM
auvenshine
auvenshine's Avatar
Default 1966 mustang
Thanks for info from previous post about car going dead sitting. Replaced voltage reg. same thing Un plugged voltage reg. over night battery didnt run down until I hooked voltage reg. back up then it doesnt have enough fire to start. Any more thoughts would be appreciated. Thanks Steve
auvenshine is offline
Old 03-08-2009, 09:24 PM
Gun Jam
Moderator
Gun Jam's Avatar
http://cgi.ebay.com/Fluke-True-rms-M...QQcmdZViewItem
Gun Jam is offline
Old 03-09-2009, 02:41 PM
jlg2002
jlg2002's Avatar
You have a very large load taking your battery down over night (or a battery with just a top level charge on it) Close the car doors and unhook the neg battery terminal, slowly connect it and look for a spark (that indicates a drain). two ways to do this from here:
1st (best way) get an ammeter of at least 25 amps, hook it up in series with the negative terminal, and look at the actual drain current. If more than .5A that's a load. Start disconnecting components in the car and look for a light that shouldn't be on
(if less than .5A, it 's in the battery, replace it.)
second way start disconnecting all of the electrical components in the car, pay attention to things like glove box and trunk lights.
jlg2002 is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
chain
08-17-2015 08:52 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1966 mustang
