1966 mustang
1966 mustang
Thanks for info from previous post about car going dead sitting. Replaced voltage reg. same thing Un plugged voltage reg. over night battery didnt run down until I hooked voltage reg. back up then it doesnt have enough fire to start. Any more thoughts would be appreciated. Thanks Steve
Location: Detroit; where the weak are killed and eaten.
http://ocw.weber.edu/automotive-tech...detestselector
the buzzer will go off if a wire is shorted together, to test put the 2 DMM leads together, the buzzer will go off.
Take one of the leads and put to the positive terminal of the battery and the other to the negative side of the battery, if the DMM beeps you have a short between power and ground, the only way to really fix it is to get wiring diagrams of the mustang online, which are widely available
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
