Carb advice, '70 302 carb on '95 GT?
I have a '95 GT 302 engine w/ edelbrock Performance RPM intake. I'm swapping this engine with my original 1970 302. The original 302 is just the basic engine not a boss or anything like that. Can I use the old carb? What would the performance and gas mileage be like? Should I buy a new carb? If so what would you recommend? This is going to be a summer driver for me and the family. Your help and advice is appreciated.
This will help with alot of the questions
https://mustangforums.com/forum/clas...-question.html
The 86 and 95 engines are pretty much the same. All your '70 stuff will bolt up BUT you'll need an AOD flexplate if you have a C4. You'll have to swap out the timing cover and water pump because the 95 has a short pump and cover. You'll need to add a fuel pump eccentric if you're using the mechanical pump.
Galactic
04-29-2019 02:56 PM
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
