9 in housing
9 in housing
My boss has a 9 in housing that he wants 50 bucks for. He said he has a set of axles that he would get rid of too and I think that he said that they are 28 spline. Now it is a small bearing housing too. What kind of cost would I be looking at to build it? What gearing should I be looking at for a turbo set up with a T5 tranny? I dont know the width of it and if it would need to be cut down to fit my 65. If I had it cut could I have the tubes changed to a big bearing? Should I just pass it up and find something better?
first off, even a 28 spline 9" is strong.
the final gear ratio will depend on many factors- particularly where you want to make power (what is the engine designed for- street, road course, drag racing?). plus, the size of the turbo will need to be considered as larger ones take longer to spool up and provide higher rpm power. I suppose as a very general guideline- the bigger the turbo, the higher the power band, and higher numeric gears are needed. plus, as an advantage- the higher gear ratio will help counteract any turbo lag that you will feel.
first off, even a 28 spline 9" is strong. shortening it may cost some money or time (depending on your skills), but will be worth it. heck, for $50 I'd buy it.
This will help, I normally try for a 350 and it seems to cover the rpm band very well. You can plug the numbers and see what you have.
http://www.kabamus.com/garage/gears.html
yeah 28 spline would be ok unless you got some insane engine and slicks.Your 3rd member case and diff are the weak spots.If you change bearing size i would go torino its more of a small and large mix its what currie uses.
so he said that it is 54 1/4 flange to flange. came out of a late 60s cougar. My 8 in out of my 65 is 53 1/4 if I am measuring the same as he did? Is an extra inch that big of a deal. You are talking a half inch longer on either side.
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
stangin1996gt
09-21-2015 11:01 AM
