window trouble
RE: window trouble
Yes, i've taken the door panel off. It's not the rollers, it's where the arm from the crank connects to the scissors, The arm keeps popping out. Is something supposed to be holding it on?
RE: window trouble
there are only a few parts to make the window go up and down. One part is the door window regulator with arm $29.95. The second main part is the window regulator scissor assembly $32.95. If you look up National parts Depot or Paddock ,or any vendor of your choice you will see the parts I described. Do a search on the internet for these for mustang parts places. You will see pics of what you may need.
RE: window trouble
I am having trouble with the rear side window on my 66. It seems to "fall off the track" sometimes. How do you access the window mechanism? Its not as obvious as with the front window where you can just remove the door panel.
Thanks
Thanks
RE: window trouble
ORIGINAL: 6mustang6
I know the parts. I have them, what connects the REGULATOR ARM TO THE SCISSORS?
RE: window trouble
DreadPirateRoberts
09-26-2015 02:11 PM
