Please help
Please help
I have a 65 fastback with a 289 2 barrel carb. I recently upgraded to a edelbrock 600 cfm carb on top of an edelbrock performer manifold. im having issues figuring out the tranny linkage and foot pedal linkage the new carb and manifold. Please help with ideas.
you can use your existing linkage but will need to pick up a piece for the carb. Go to your local auto parts store and pick up a Mr. Gasket Carb bushing/Pivot, or similar, part number 720-1512. this is a common adapter. Attach it to the carb, and you should be able to feed the existing throttle arm through this adapter. You might have to adjust your kickdown at the tranny, engaging at wide open throttle. Let me know if this works or if you need any additional input.
I cant be the first to have this issue. please help with pics and more ideas
