Granada vs Mustang spindles
KISS
Just throw a 1/16 shim behind the pads and it will double as a heat shield too. Or if you don't like that idea just get the 1" thick Granada rotors from any race supply parts house. The're only 30 something bucks each and you have a choice of 7/8 or 1" thick.
Cute emotion icons and platitudes about KISS don't make the engineering good. A shim does not fix the problem of the brake pad backing place falling out of the bracket when the pad and rotor are at their wear limits. As I have already suggested, using a correct 1.025" thick rotor is the proper way to fit the SN95 caliper and pad set combo.
The new rotor and bracket kit will soon be available.
just trying to help bro
Only if you buy them from a place that does not give you a choice.
http://www.southwestspeed.com/?sec=view_part&id=24400
degins,
Sorry to post to such an old post.
I am out stationed in Taiwan. My car in AZ, is getting ready to go back on the road after years of sitting. I installed 76' Granada spindles on it back in 1990, changed out the outer tie rod ends, rebuild the entire suspension, and lowered it 1.5". It is a manual steering unit with no bump steer issues. What are my options for upgrading the rotor and caliper? My drum brake spindles are gone.
I am looking at SSBC kits, but I am unsure of the braket bolt pattern and spacing. I think the kits are set up for bolting on to the V-8 drum brake spindle, but of course mine has changed.
I am already running 17" wheels so space is not a concern. I am looking to find a kit that will utilize the 76" Granade disc brake spindle.
Any assistance is appreciated.
Thank you
Thank you
If you already have 17s the best bang for the buck is the cobra brake swap mustangsteve and streetortrack.com both have brackets to use them.The cobra brakes are 13 inch 2 piston pbr the same thing baer uses and the twin to there cheapest kit.
Just for the record
I installed OEM style 4 piston KH front disc brakes on my 67 and am very pleased with ease of install and performance.
I have not installed a proportioning valve.
My brakes are far superior to drum/drum.
I like that I can use my 15" TTD.
degins,
Thank you
Thank you
Nice to know I'm not the only person who prefers classic zero offset wheels to the new high offset wheels.
