Cylinder head volume for 83' 351w heads?
03-25-2009, 01:25 PM
I need to know the head volume for a 83' 351w, to make sure I don't go to high on compression.
Also what is too high for pump gas?
03-25-2009, 01:30 PM
Big. Very big. Don't run those. If you want better factory heads, GT40 heads essentially use 351W ports with small chambers.
03-25-2009, 01:32 PM
I am going to have to use them for several months.
03-25-2009, 01:43 PM
I believe it to be 69cc. Can anyone confirm?
Why? What's wrong with your heads? The chambers in those 351W heads are huge and will drop your compression quite a bit.
03-25-2009, 01:49 PM
I am getting the motor rebuild right now, and do not have the money for new heads.
http://kb-silvolite.com/performance....tails&P_id=142
I have these picked out to go with the heads later (60cc). Would a 8.6 compression rate be that gross for now?
03-25-2009, 02:22 PM
Oh, you're actually running a 351W? 8.6:1 isn't horrible, but it's not good either. I can't say that those heads are 69cc, though. They may be more than that.
03-25-2009, 02:28 PM
You decided to do with the Comp Cams Roller cam kit? My understanding is that the Roller cam will work better than a flat tappet cam at the lower CR.
03-25-2009, 03:11 PM
Yes this is for a 351w.
Yeah Adrenolin, that setup you posted was to nice to pass up.
03-25-2009, 07:55 PM
Bump.
Would 8.6:1 make the car a terrible ride?
