Gauge Feed Wire Harness HELP!!!
Old 03-31-2009, 06:24 PM
rst08tierney
rst08tierney's Avatar
Question Gauge Feed Wire Harness HELP!!!
FIRST QUESTION
Alright, Maybe I have this all backwards.
I currently have a hacked up gauge harness in my 67 and wanted to get the proper one installed before I switch my gauge cluster out. Here is the deal I was told the following
BLACK SHOE LACE WIRE goes to Temp Sender (red/green)
RED WIRE goes to the Coil (red/white) Im my case a Mallory Box
WHITE goes to the Oil Sender (white/red)
Is this correct or absolutely wrong. The reason I ask is look at my oil sender unit. No way any 3 of those wires will fit let alone the white with the speaker terminal connection which I was told thats the correct wire. Im pretty sure they have the coil and oil sender wire backwards unless there is another wire that plugs into the end and on to the oil sender
What is the correct way. I still need to make the harness longer to work so I dont want to play the guessing game. Im thinking I was told the incorrect way.
SECOND QUESTION
The last picture is out of the NPD catalog. According to them my current sender requires a spade connector (the one on the right) What does the spade connector look like?
Is it easier to just buy a new oil sender with the threaded stud connector?
As usual, thanks for the help and yes im lost.
Attached Thumbnails Gauge Feed Wire Harness HELP!!!-dsc00389.jpg   Gauge Feed Wire Harness HELP!!!-dsc00391.jpg   Gauge Feed Wire Harness HELP!!!-dsc00397.jpg   Gauge Feed Wire Harness HELP!!!-dsc00398.jpg   Gauge Feed Wire Harness HELP!!!-dsc00399.jpg
rst08tierney is offline
Old 03-31-2009, 11:15 PM
rst08tierney
Let me add some more important info.
289 no tac/no ac
Old 04-01-2009, 11:47 AM
MIL1ION
MIL1ION's Avatar
This can't be an original harness ?
Sounds like an aftermarket harness.
http://hammar.dyndns.org/~djhamma/wi...67/67instr.jpg
http://hammar.dyndns.org/~djhamma/wiring/1968/E3.jpg
MIL1ION is offline
Old 04-01-2009, 12:21 PM
rst08tierney
No its actually a re-pop of the original. Thanks for the diagram, but it does not show the connection type for the senders.
Old 04-01-2009, 10:02 PM
rst08tierney
sorry guys, still need some help
Bump!
Old 04-01-2009, 10:17 PM
EZFEED
EZFEED's Avatar
Hey, I have a wiring manual at the house that I can nab tomorrow and scan and post some pics for you. Just please remind me because I will forget
Email me at march21_1861@hotmail.com and send me a note, you can do it now. I know this sounds funny but even if I wrote a note now there's a good possibility I would forget it somewhere. I check my emails just before leaving to go to work so I will catch it. I'm pretty sure it covers 67-68 as well, its one of those with detailed pics and routing instructions as well as colors.
I work 6pm-6am so it will be sometime after 6pm till I post.
EZFEED is offline
Old 04-02-2009, 12:08 AM
rst08tierney
Thanks. The main pics I would be looking for is inside the engine connecting to the senders.
Old 04-02-2009, 12:33 AM
EZFEED
EZFEED's Avatar
Got'em, just shoot me an email so I will remember when I leave for work tomorrow. I also have a 67 and can take pics for you, mines a 6cyl but the senders are the same and so are the connections, just not the locations and length of wires.
EZFEED is offline
Old 04-02-2009, 10:37 AM
rst08tierney
I have seen the harness for the 6. That looks correct because it lacks the "speaker wire" connection for the oil sender. Let me know if your harness is stock or a re-pop of the stock. Pics would be very helpfull. I will shoot you an email. Thanks
Im still open to anyone else who has a clue on this!!!
Old 04-03-2009, 11:37 PM
rst08tierney
Still looking to get this one answered. Any takers?
Quick Reply: Gauge Feed Wire Harness HELP!!!
