Broken Axel Help
Ew...my sympathies.
The best way to get it out would be to weld a loop of some sort to the end of the axle, then pull it out with that. The next best bet would be to try to drill the axle (may not work well), tap it, and thread in a lage bolt to pull it out with.
Pull the axle on the other side. Now you have access to the broken axle from the diff side. Maybe you can get someting long and narrow and poke it out from the diff side. If it's broken to the inside of the seal, have someone ready to guide it out through the seal.
09-25-2015 06:58 PM
SterlingStunner
5.0L V8 Technical Discussions
09-04-2015 06:28 AM
Calizic
08-28-2015 01:46 PM
