Gasket Material for Taillights, Chrome
Old 04-01-2009, 11:23 PM
Fordication
Fordication's Avatar
Default Gasket Material for Taillights, Chrome
What do you guys use to replace the sticky dough like material that was used in the tailights bolts washers on your mustang. I have a 72 but I am sure that the black dough like product was used on several years of the mustang. Also what do you use for headliner padding on the 71-73. I am putting her back together and these are the main holdups. Thanks
Fordication is offline
Old 04-01-2009, 11:30 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
bedding and glazing compound
rmodel65 is offline
Old 04-01-2009, 11:45 PM
Fordication
What does it look like when its out of the tube and does it get hard. Man thats a loaded question. LOL
Old 04-02-2009, 12:00 AM
Fordication
BTW I am talking about the material used on the bolts and nuts that is a rubber like washer but it actually a dough like seal. Thanks
Old 04-02-2009, 12:29 AM
tx65coupe
tx65coupe's Avatar
It could be 3M strip caulk. i'm not sure though. This is what I used on my tail lights.
http://solutions9.3m.com/wps/portal/...be6DTWTJQPBBgl
tx65coupe is offline
Old 04-02-2009, 12:39 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the bedding and glazing never gets hard that what seals the windsheild and rear window seals on cars with gaskets like 65-68 its also used for the water shield behind door panels etc its
you could use the strip caulk too, but i like the bedding cause its easy to use and works in a lot of different places
rmodel65 is offline
Old 04-02-2009, 12:58 AM
Fordication
Yep the strip calk was what I was looking for. Thanks. Now what do you guys recommend to use as a modern pad under the headliner and under the rear window area. Thanks
Old 04-02-2009, 01:19 AM
tx65coupe
tx65coupe's Avatar
I remember using the bedding/glazing stuff on my front and rear windows.
Old 04-02-2009, 05:14 AM
kalli
kalli's Avatar
if you're looking fro rubbery/doughy sealant (i haven't seen that in my taillights) you can always use the rubber strips that modern cars have under their fenders. You should get a full meter for a few bob.
sincde I don't know the english name for it, it might well be what rmodel is talking about. we simply called it chewing gum
kalli is offline
Old 04-03-2009, 01:33 PM
Fordication
Yeah I used the stuff in the plants back in the day and we called it donkey dick because it came in big rolls and looked like a black donkey dick.
Dathan
10-05-2015 05:52 AM
wraith777
09-28-2015 10:49 AM
Demodulates
09-18-2015 11:14 AM
EASTIDEE123
09-15-2015 11:08 AM
SilverStallion05
09-05-2015 10:48 AM
Quick Reply: Gasket Material for Taillights, Chrome
