Any problems with the studs?
I have a stock 289 and I am about to change the cam, intake and carb. I am going put in a comp cam extreme energy xe268h with the springs that go with it. My question is has anyone had any problems with the studs pulling out of the heads?
Err...well, it's possible with that cam. Not saying it's definitely going to happen, but if you start to hear a loud tapping, shut the motor off immediately.
My main concern would be the bottom end, though. Is it stock? Rebuilt? What kind of rod bolts are you using? That cam will wind all the way up to 6k (I know, I used to run it), which is well past where I'd trust stock rod bolts.
Make sure to use ZDDP additive, or oil containing enough ZDDP along with the break-in lube or you could ruin the cam right out of the gate.
I apologize if I'm stating the obvious, I'd just hate to see you eat a cam.
With stock rod bolts, I'd stick to no more than the XE256H. That'll get you plenty of pep without having to worry much about breaking things, and you shouldn't have valve clearance issues with that cam either.
If you have press fit studs, nows' the time to get rid of them. Although you can do the job with the heads on, it's so much easier to do it with the heads off.
If you're installing a new cam with more lift and duration, you definatly need to clay the pistons. The heads just have to come off for this kind of job.
Pulling the heads really isn't that big of a deal on these old cars. 4 extra gaskets, a few more hours, and you'll have great results. I'v replaced both head gaskets on a '66
in less than a day.
in less than a day.
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
