I've put about 2500 on the new xe256H from comp cams
Old 04-05-2009, 07:40 PM
Red Coupe
Red Coupe's Avatar
Default I've put about 2500 on the new xe256H from comp cams
I don't drive the car often so it has taken me over a year to put the miles on it. I have had to adjust the rockers a coupe of the times and have problems with valve train noise.
So... today I take off the intake and remove the rods and lifters and note that the lifters on the left bank (cylinders 5-8) and very worn while the right bank lifters are pretty good.
The exhaust lifters on 7 and 8 are actually worn shorter than the others which explains the adjustments and noise. All of the lifters on the left are worn unusually.
When I peek down through the lifter valley at the cam I notice that the cam lobes seem so far aft that they only come in contact with 50-75 percent of the lifter surface. This is only on the cylinders 5-8 and it gets more out of line as it gets closer to the number 8 cylinder
Shouldn't the cam lobe line up neatly with the cylinder that the lifter rides in?
Why would it only be off on the lobes that serve the left side cylinders while lining up ok on the right side?
I double checked the grind number on the cam before install it is FS XE256H-10 and the block/heads are original 65 289 with late 64 and early 65 date stamps.
Summitt racing has not been very helpful.
Red Coupe is offline
Old 04-06-2009, 12:30 PM
Red Coupe
Red Coupe's Avatar
To clarify my question, what would make the left hand bank of lifters have only 1/2 a cam lobe to ride on while the cylinders 1 to 4 on the right seem normal?
cam is comp cams xe 256 H
engine is a 289 in 65 coupe.
Old 04-06-2009, 01:11 PM
kalli
kalli's Avatar
maybe the cam lobes are worn? no proper break in or no ZDDp in oil?
kalli is offline
Old 04-06-2009, 02:16 PM
TexasAxMan
TexasAxMan's Avatar
I'm not sure of the answers to all your questions so I'll leave to more experienced members to help.
But, the lifter has to be slightly offset from the cam in order for the lifter to spin and thus wear more evenly.
TexasAxMan is offline
Nick Oliver
10-17-2018 04:22 AM
Luke9222
10-22-2015 11:55 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: I've put about 2500 on the new xe256H from comp cams
