how can i tell if my mustang is "numbers matching"?
i have a 67 coupe, 289, c4... apparently back in the day they didn't write VIN#'s on everything. i heard that i have to check the date codes? how do i go about doing that and where do i look?
Thanks
Thanks
You can look up the casting date codes but it's not like a chevy where you have numbers to match
https://mustangforums.com/forum/gene...atching-s.html
http://www.aacncclub.com/FORD_HEAD_CASTING.html
It is my understanding that numbers matching tends to refer to simply having the right engine for the car. I don't think Ford actually used the numbers to match a particular individual engine to a particular individual body. So, I think if your car is supposed to have a 289 and you have a 289 built at the right time you have numbers matching.
i took the seats out once before and there were no papers underneath them, would it be under the carpet? and basically you cant tell if its the exact motor that came with the car, you can only approximate it using the date codes?
I believe thats correct, a C code car in 68 was a 289 2 barrel. If thats the engine you have then it matches the vin, even if someone changed the engine at some point. I believe that the older chevy's had vin numbers on the block that matched the car vin, not so with Ford.
And yes, because Ford didn't stamp matching numbers on everything, as long as your engine has date codes for roughly the same time the car was built you could call it date code correct. If the engine is coded for 6 months after the car was built you might start to worry about it not being the original engine, but stranger things have happened.
01-06-2016 07:03 PM
08-14-2015 12:27 AM
