Door hinge pin likes to come out....pics
In the below pictures you can see the pin in the hinge. Over the course of a couple weeks it will slowly work its way up like that. So i grab a hammer and hit it back down but that's not keeping it down.
Any ideas?
Any ideas?
The pins should be peened at the bottom to prevent the pin from working out. On my 1970 stang, the factory pins were flattened on the bottom and the bottom of the pin had to be ground off to remove for replacement of the pins and bushings. I just put a small tack weld on mine when I rebuilt them.
yah. if you are as lazy as I am, open up the bottom part so it physically can't come up, or do what Joe67 says or tx65coupe (clip)
proper way to do it is just to replace the parts (rebuild kit as Mark says)
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
inyadreems
08-21-2015 09:10 AM
