ROCKER/PUSHROD PROBLEMS
The problem is simple, with the style rocker arms you are running you need PUSHROD GUIDE PLATES!....
You have rightly recognized part of the problem, the lack of "side rails" on the rockers. You have of course noticed that Ford used rocker with the trench to ride over the end of the valve stem. this causes the rockers to "self center".
Roller tip rockers will require guide plates on most all SBF heads. Guide plates will REQUIRE HARDENED PUSH RODS as well. (This is because the pushrods will drag on the guide plates).Since they are bent, now is the time..
The guideplates will fit under the rocker studs. The plates will raise the rocker studs about a 1/4". This will PROBABLY help your lifter geometry, (the angle that the rocker sits against the valve and pushrod). You will need to get the right push rod length to make everything right.
I had never seen them before, when I went back over the thread and saw your post I knew I had made a mistake!
Since then I have done a little more research on the matter and possibly the OP has another complication, but having never worked with STOCK SBF heads I am not far enough along in my research to be sure...
I am assuming that it may be problematic to install guideplates on some Windsor heads... because of the way the stock lifter bolt down... but the OP may already have screw in rocker studs...??
OK GUYS........SORRY.........about the caps lock and thanks for all your help..(everyone).sorry about being rude at first but I never seen caps as being so annoying to others....maybe I was yelling about screwing up the ride when I thought I was almost complete after 4 years,and the lack of funds, and now taking another step backwards again.....Thanks once again for everyones help and once again I will say I'M SORRY for the caps....
