1971 Mustang
Old 04-28-2009, 09:53 AM
1971mach1
1971mach1's Avatar
Originally Posted by 71stang99
On a side note, how hard is that to smog in california?
No smog check required for cars older than 1975.
1971mach1 is offline
Old 04-28-2009, 07:44 PM
71stang99
71stang99's Avatar
wow, that is less stringent then parts of Nevada, specifically Las Vegas. I would have never thought that.
71stang99 is offline
Old 04-28-2009, 08:32 PM
andrewmp6
andrewmp6's Avatar
If your going to drive it everyday i would get a overdrive tranny rear gear the rear end to match maybe efi it too.
andrewmp6 is offline
Old 04-28-2009, 09:16 PM
71stang99
71stang99's Avatar
EFI is big $$$, 3k or so
Old 04-28-2009, 11:52 PM
vineman
vineman's Avatar
efi is not that expensive if you shop smart. I got my full RUNNING setup out of a donor car for $500 with trans and everything. You run into high $ when you pull from a mustang or get it brand new. They have efi in more cars than mustangs that'll work.
vineman is offline
Old 04-29-2009, 06:31 AM
andrewmp6
andrewmp6's Avatar
The 351c is a little harder to do but can be done.
Old 04-29-2009, 12:08 PM
vineman
vineman's Avatar
well, yeah i guess if you were keeping the 351c block. didn't really think of that.
vineman is offline
Old 04-29-2009, 04:31 PM
1971mach1
1971mach1's Avatar
For EFI, check out: www.affordable-fuel-injection.com
These are ALOT cheeper than $3000, some kits are only $950
and the "Throttle Body" kits fit almost ANY engine.
The TBI unit just bolts on to your intake where your carb was.
No need to dig thru a junkyard for something that may or may not work!
No need to adapt something for the 351C.
I haven't tried one of these yet but it would probably improve your MPGs.
I bet the 351 would still be much worse than the OP's Volvo though.
Old 04-29-2009, 09:54 PM
andrewmp6
andrewmp6's Avatar
tbi is a step above a carb but not much.I rather have a multi port efi but its a little harder to do on a cleveland.There is a way to make the efi off the 302 work but i never seen it done myself.
Old 04-30-2009, 10:11 AM
1971mach1
1971mach1's Avatar
Not sure why you say that??, my 89 Chev Blazer had a very similar TBI unit on the 4.3 v6. It ran great for 150K, very reliable, very powerfull (for a v6), lots of torque.
Quick Reply: 1971 Mustang
