Rear axle swap???
Old 04-25-2009, 10:11 AM
rhino_ourulz
rhino_ourulz's Avatar
Default Rear axle swap???
i have a 1968 mustang coupe and im wanting to swap my rear axle out with a newer one. I would like to have a lowered gear rear end, 3.73, and disk brakes. Any suggestions?
rhino_ourulz is offline
Old 04-25-2009, 10:20 AM
Starfury
Starfury's Avatar
Why do you want to swap the rear? What's wrong with yours?
Starfury is offline
Old 04-25-2009, 12:49 PM
Deviousfred
Deviousfred's Avatar
It may take some extra work and won't be a bolt on but if you can find an 8.8 with the correct or close enough axle width and disk brakes you could weld leaf spring perches on it. This swap seems to be becoming more and more popular and starting to grow me. I may do one to my next coupe.
Deviousfred is offline
Old 04-25-2009, 02:38 PM
kalli
kalli's Avatar
+1 if you just want different gearing, change ring and pinion. not the full axle ?!
kalli is offline
Old 04-27-2009, 05:25 PM
rhino_ourulz
Its just not in very good shape. Ive had to drop a new motor in it, overhaul the trasmision and now were thinkin thats the next thing to go out on us. I just want a better rear end the will hold up to my engine.
Old 04-27-2009, 07:24 PM
Starfury
Starfury's Avatar
You keep leaving out critical info. What rear end do you currently have? Was it originally an I6 car? "It's not in very good shape" isn't descriptive. What makes you think the entire axle housing needs to be replaced? The weak points in the axle are the differential pinion gears and the ring/pinion gears.
Starfury is offline
Old 04-27-2009, 07:37 PM
Norm Peterson
Norm Peterson's Avatar
Maybe knowing what the new motor is would help - even 8" isn't all that tough if you're making lots of torque (or have a heavy flywheel) and have lots of rear grip.
If you decide to go with an 8.8, make sure to get Ford or Ford Racing gears (as opposed to Motives). Plenty of threads on this in the S197 sections here (2005 - 2010).
The 8.8 is becoming a favored axle swap with a lot going for it (weighs less than a 9, remains in current production). There's even a current thread over on maliburacing.com (suspension tech forum, if you're curious) where a guy is in the final stages of putting together a kit for swapping the 8.8 into the '78 - '87 GM intermediates (replacing the OE 7.5/7.625 corporate axle), and he has at least one other 8.8 swap kit in mind (forget offhand just what it's going into next).
Norm
Norm Peterson is offline
11-10-2015 11:39 AM
97SN95GT
09-13-2015 09:45 PM
Dragonus18
09-09-2015 01:21 AM
Webster454
09-07-2015 04:59 AM
09-03-2015 07:14 PM
Quick Reply: Rear axle swap???
