Distributors
Distributors
i am planning on switching over my mustang (351w) to electronic igntion. i have been loooking at some on ebay but not sure about them and what all i need to swap the electronic ignition on a mustang.
1. SBF FORD HEI Distributor 351 351W Windsor Mustang
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
with this distributor would i need to buy a coil with it or is it built into this one. this distributor also looks like it belongs to a chevy. (my buddy put one that look like this in his 79 camaro w/ 400 sbc). if i get this distributor what else would i need to get.
2. Mallory E Fire Distributor # 1255404
i do not know anything about this distrubutor but what else would i need to buy if i get this distrubutor.
3. Mallory # 8768701, MBI Vacuum Advance Comp 9000 Distributor
will this one even work with my 351w. if so what else would i need to get for it.
also which one do you think is the best distributor. Thanks
I guess you are wanting a ready to run dist with the ignition built in, The mallory is pobably the best one as it has pogrammable ign curves and is laptop programmable. The HEI is a chinese procomp they work ok but they also make a ready to run billet which uses a seperate coil and much smaller. The msd and mallory will be 300-400 bucks I'm sure. You can also go to your local auto parts and get a rebuilt duraspark for around 60 bucks or so (you will also need cap adapter,cap and the right wires) you can use it with a stock blue strain module, a gm hei module, a chrysler module or just about any aftermarket ignition like msd 6al,accel 300+,mallory hi fire,summit racing (same as mallory) or any other ignition that has a trigger. Depending on the ign you use you want to gap plugs between .45 and .65
Any one of those will work with your 351, the bottom two will require a coil in addition to the distributor.
I like the simplicity of the HEI, one wire does it all, but I prefer the American made ones over the Chinese repops. We used a Mallory HEI on my son's 351, and it works great. It is available from summitt for about $150.00. Down side of these is that the cap is big, so they don't look as cool as others, but I like then anyway, breakdown parts are available, IN STOCK, and CHEAP in any parts store in America.
You need nothing else for either of the other two, and I would say if they go cheap enough I would buy them, no reserve, bid on both of em...
If you are running a ROLLER CAM you will need to buy a steel or mellonized gear for any of the three. The Iron gear will not last on a roller cam. Gears are not too bad though.
Whenever you are talking about Chinese import products you will get responses saying that whatever it is is crap. A lot of crap does come from China, but there are many other things that are of very good quality. Having said that, I bought a new Procomp HEI distributor off e-bay for $40. I won't be able to run it for several more months, but the distributor looks to be of decent quality. The shaft turns very nice in the bearings and I pulled the cap and it looks good to me inside and out, but then again I haven't run it yet.
But other than my DESIRE to buy USA made stuff, when I was looking at the pictures of MANY of the ProComp distributors on eBay, they appear to have to have what looks like circuit boards under the cap. Which makes me think that if something goes bad in this board it MIGHT just be tough **** when it comes to REPAIR.
I can say with certainty that the Mallory HEI units accept OEM parts, cheap and east to repair.
I had assumed it was USA made I guess I did not look as closely as I should have.
"All electrical parts are compatible with all other Procomp and stock HEI distributors."
Can't speak for any but the one I have, but my Procomp does not have any exposed circuit boards under the cap and has what appear to be stock fitting components (GM of course) including the module. On top of that procomp advertises the that:
In the past I have CONSIDERED buying one of these distributors, but as I said, I looked at the pictures and just could not make myself take the chance..
Sorry to bring this back from the dead, but for some time I thought I had screwed up, I checked the Mallory HEI carton that my sons distributor for his 302 came out of...
It was marked MADE IN THE USA...
I will ASSUME the previous 2 Mallory HEIs I purchased over the past couple of years were made in the USA also.
I USUALLY try real hard to buy American when I have a reasonable American choice.
