firewall to engine ground
i just got a strap for the firewall to engine ground and i'm wondering where to connect it to the engine. does anybody have a pic of a good place to connect it to the engine? thanks
Anywhere with solid metal-metal contact. Try to bolt it up to something iron(directly too the block). If you go through aluminum(if you have any, heads, intake, bellhousing etc) then you're running electric current through differing metals, and you can get galvanic corrosion(the metals might react and one of them corrodes).
On mine I actually ran a wire that's bolted directly to the block on one end and the (-) batt terminal on the other, with an additional wire from the (-) batt terminal direct to the chassis. Jumping from the block to the chassis accomplishes pretty much the same thing, anything grounded to the chassis then goes through the block and from there through the (-) cable on the starter back to the batt.
there is (or should be) a little bolt at the rear of the block specifically for the ground. it threads right into the block, kinda hard to miss it
