Replacing 66 289 Water Pump
I am going to be installing a new water pump and am wondering if any of the bolts go into the water jacket and need sealer on them or should a use anti seize. What is the best way to do this.
Ya know, now that I think about it a little more, you're right, none of the water pump bolts go into the water jacket. That said, some of the bolts that hold the accessory brackets on go into the water jacket and may need to be removed to get the water pump out.
Get a piece of cardboard and trace the new waterpump on it. Stick a screwdriver in the bolt holes and through the cardboard.
Now, as you remove the bolts from the motor, stick them in the associated hole location in the cardboard.
