Spark plug threads are wet?
Old 04-30-2009, 07:52 AM
straw1628
straw1628's Avatar
Default Spark plug threads are wet?
Last night I pulled all the plugs in my car to give them a look as I tune the carb etc. Anyway, all of the plugs had wet threads, some worse than others. Does this mean anything? Is this because of flooding? It looks like oil on the threads. The plugs look dark, like they are burning rich. Thanks
straw1628 is offline
Old 04-30-2009, 08:25 AM
urban_cowboy
urban_cowboy's Avatar
Post some pictures. Wet threads could be anti-seize. Real black porcelain is rich.
urban_cowboy is offline
Old 04-30-2009, 09:54 AM
trashline
trashline's Avatar
could be oil leaking from your valve covers.
trashline is offline
Old 04-30-2009, 09:55 AM
69mach1377
69mach1377's Avatar
Sometimes leaky (vapor more than anything) valve cover gaskets lead to oily threads.
69mach1377 is offline
Old 04-30-2009, 10:13 AM
straw1628
straw1628's Avatar
There is no anti seize on the threads, I put them in. Above the plugs, below the valve covers, looks dry. Maybe the car has swine flu. I dont know. Someone had told me once it could be related to the lifters. Does that make any sense?
Old 04-30-2009, 12:34 PM
67mustang302
67mustang302's Avatar
If the porcelain and electrodes are clean, then it's probably leaking valve covers.
67mustang302 is offline
Old 04-30-2009, 01:51 PM
JMD
JMD's Avatar
Take care of the rich mixture, and then look into the wet threads if the issue still exists...
JMD is offline
Old 04-30-2009, 02:18 PM
109jb
109jb's Avatar
So how exactly do leaky valve covers get oil on the THREADS of the spark plug. At the top of the threads the spark plug seals to the head. Oil would have to get past that seal before it could get on the threads. Unless there is oil sitting in the spark cavity when the plug is removed the valve cover leak theory is a bust in my opinion.
109jb is offline
Old 04-30-2009, 03:13 PM
67mustang302
Oil follows heat and can get past unbelievably small places and seals over time. And as an engine heats up and cools down and expands and contracts seals such as spark plugs move around a tad, and the oil creeps it's way through, eventually. And a spark plug seal doesn't even need to be, and may not be 100%(really the only way to have a 100% seal is to weld it together), compression and combustion occur so rapidly, that there's no time for pressure to leak down through a 99%+ seal. Plus you have oil migration as you take plugs out and put them back in.
Old 04-30-2009, 03:36 PM
109jb
109jb's Avatar
All the stuff you said means that there has to be oil in the spark plug cavity on the head basically sitting around the plug. I would think if that were the case the original poster wouldn't have even asked the question.
109jb is offline
Quick Reply: Spark plug threads are wet?
