Engine and Power Problems
Ok here are my two current problems. I have been having trouble with my Holley carbs running extremely rich. (Black smoke even at idle) I went ahead and bought a new carb and installed it last night. Everything was working great. I have gone from a 2 barrel to a 4 with a Edelbrock 289 Torker intake. With the new carb everything seemed to be working fine until we started hearing a knocking coming from the back passenger side of the engine and white smoke. We shutdown the motor and then tried to start it back up but now we aren’t getting any spark from the coil. It looks like there is something between the battery and the coil that is killing the power. Does anyone know what could have caused either of these problems?
The coil voltage is correct.
It sounds to me like two different problems. One may be ignition related, but the white smoke/knocking problem sounds like an incorrect intake install. Coolant is leaking into the combustion chamber.
Yep, I think I would drain the coolant, pull the sparkplugs and roll the engine a few times.
Since water does not compress, water in a cylinder can be problematic...
You could bend a rod and/or crack a piston... I know...
If it is not too late already, it is likely a good thing you lost your ignition.
ShaneB26154
35
03-04-2021 04:05 AM
KEM Motorworks
08-14-2015 10:13 PM
