not getting a clear answer on brake swap
Old 05-01-2009, 05:35 AM
sixt5
sixt5's Avatar
Default not getting a clear answer on brake swap
im going to be putting the 03 cobra brakes on my 65 coupe. currently have power drums all the way around. will my booster work? i know i have to get a dual master cyl, but dunno about the booster.
sixt5 is offline
Old 05-01-2009, 06:56 AM
JamesW
Moderator
JamesW's Avatar
It's an apples and oranges question. The booster has nothing to do with your brakes working. The problem is running the booster and the dual M/C.... will you have the necessary shock tower clearance. the cobra brakes will work with either a bosted single MC or a nonboosted dual m/c.
JamesW is offline
Old 05-01-2009, 10:29 AM
groho
groho's Avatar
I've read multiple times that the smaller power assist (7") unit is needed for 64-66 conversions to clear the tower brace. Separate issue, I also believe the wheel/hub offset for the 03 is going to be different than 64-66. You might want to check that in case you have replace wheels or get spacers.
groho is offline
Old 05-01-2009, 10:34 AM
1slow67
ROTM Moderator
1slow67's Avatar
Same person asked a question similar to this on TMS.
1slow67 is offline
Old 05-01-2009, 11:12 AM
sixt5
sixt5's Avatar
ya im getting mach 1 wheels with spacers, wheels arent going to be an issue.
can i buy a factory power disc booster and master cyl and be done?
sixt5 is offline
Old 05-01-2009, 01:19 PM
kalli
kalli's Avatar
from what I know stock will never fit without cutting your crossbars and will be in the way of your clutch linkage (if you have manual). at least that was what everyone told me who I asked about it. chokostang indicates the same.
Since he sells breaks for classic stangs on a daily basisi I'd say you're best off talking to him.
kalli is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
04stangman
09-17-2015 01:45 PM
DoctorScary
09-09-2015 07:53 AM
09-08-2015 11:50 AM
Quick Reply: not getting a clear answer on brake swap
