Anyone used a Sears Engine Analyzer
http://reviews.ebay.com/SEARS-CRAFTS...00000001342626
Do any of you use this to time your engine? Or do you do use the Timing Light?
I am just curious! Also, if you use the Analyzer, what do you usually use? The RPM or the Dwell?
Thanks!
Thanks!
same here. i use a multimeter and a proper bright timing gun and good vacuum gauge and that should be it for tuning ignition and carb and something to measure rpms with.
a dwell meter is only needed for points and if you still have them there are a lot of multimeters that measure dwell and rpms as well (the car type MM).
But then again if you can get the full set on ebay for 40$, why not. I just think it's a bit bulky :-)
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
