Electrical Trouble - Please Help!!
Old 05-01-2009, 11:32 PM
justaguy65
justaguy65's Avatar
Default Electrical Trouble - Please Help!!
I am having some kind of electrical malfuction. Seems like every other time I drive my car, my instrument panel is dead. The fuel guage, temp, and turn signal indicator stop working. Also, the turn signals and brake lights stop working. It is real strange because every other time I drive it, everything works. I just don't know what exactly I should check. I really appreciate any help with this.
justaguy65 is offline
Old 05-02-2009, 02:33 AM
1965screamer
1965screamer's Avatar
I would start by checking the two connections where the wires go through the firewall. Those tend to get corroded over time.
1965screamer is offline
Old 05-02-2009, 08:42 AM
JamesW
Moderator
JamesW's Avatar
Assuming it's a 65 mustang from the name.
The fuel gage and temp are on separate circuits than the turn indicators, turn signals and brakes. Makes this problem a little harder.
Start by checking the ground wire from your instrument panel to the frame. It's a short black wire that screws into the crossbar behind the cluster. Check for security and corrosion.
Next check the connector where the steering column harness comes out and attaches to the under dash harness. pull that connector apart and check for corrosion, then use some dielectric grease on it and reseat securly.
Also check your connector that attaches to the headlamp switch for anything loose, broken or corroded. The power for the brakes and turn signals and indicators comes into and out of this connection.
JamesW is offline
Old 05-02-2009, 01:55 PM
The Ultimate Ford Info Guy
The Ultimate Ford Info Guy's Avatar
The Spot for the ground strap as James mentioned can be seen here on the dash brace with 2 black wires coming from it
The Ultimate Ford Info Guy is offline
CS2007
06-25-2019 09:45 PM
chrisdbassplayer
10-13-2015 06:53 PM
ChampInSD
10-02-2015 04:55 AM
LiquidDrink
09-29-2015 10:06 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Electrical Trouble - Please Help!!
