C4 shifting question-help
I finally got my car on the road over the weekend. It runs great however the trans shifts really early. It does go through all of the gears and into 3rd. I do not have the kick down attached. I pulled it back and tied it off on the off position, I think. I did adjust the vacume modulator clockwise and that seemed to help a little. In 3rd going 45 mph I am turning about 4000 rpms.
Not sure what's going on?
Jeff
Jeff
It sure feels like 2nd I agree. I think it is definitely going into 3rd though. I feel 2 shift points on acceleration. I haven't done anything to the tranny.
So not having the kickdown hooked up could cause it not to go into 3rd? Also, is the kickdown electric? Does it work off of the neutral safety power? I messed with the kickdown and it seems to be spring loaded to a center spot. I can pull it back off that spot but it will return when I let go. I can also push it forward and it will return. it only moves about 1/2 an inch or so. No mechanical feel at all, smoothe.
