289 and Fox Body Heads
Old 05-04-2009, 09:53 AM
dtskds
dtskds's Avatar
Default 289 and Fox Body Heads
Does anyone know if you can put fox body heads on a stock 289? If so is there a lot of machining that needs to be done to get them to work?
dtskds is offline
Old 05-04-2009, 11:32 AM
Starfury
Starfury's Avatar
All it would take are some conversion head bolts, which are available from ARP. You can also buy spacer bushings to do the same job, but I figure you need the head bolts anyway, so why not?
The question is, why are you doing this? E7 (1987) and up 302 heads have a slight improvement in the exhaust port castings, but any flow improvement is going to be offset by a loss of compression from the larger combustion chambers.
If you're looking for something cheap that will improve power, GT40 (not GT40P) heads are the way to go.
Starfury is offline
Luke9222
10-22-2015 11:55 PM
GTJIM
09-23-2015 09:59 AM
EASTIDEE123
09-14-2015 03:52 PM
ryland
09-13-2015 12:35 PM
Brian Emmer
09-09-2015 02:50 PM
Quick Reply: 289 and Fox Body Heads
