oil coming out of exhaust!
I would say it is. It happens especially if you just start it and pull it in and out of the garage and don't really drive it. The carbon builds up in the exhaust and then the moisture kind of washes it out and it looks like oil.
I'm amazed how many times this comes up on this site. It is basic physics. If you compress air you get water. It is just like your air compressor. You have to drain the water out of it once in a while. When you drive to work in the morning look and see how many people have water dripping from thier tail pipes. Almost all. It is worse on cold mornings with cold engines.
If it is oil, off the top of my head it is:
a. Bad cylinder sealing, broken/worn ring(s), scorred/cracked cylinder and/or piston.
b. Bad valve guide and/or seal
c. defective PCV valve
But chances are it is just carbon and/or normal seepage past valve seals when the car sits for an extended period.
Whatever it is, I would just drive the **** out of the car and if there is a problem it will make itself known...
