8" to 9" rearend
Old 05-05-2009, 12:18 PM
65Rocky
65Rocky's Avatar
Default 8" to 9" rearend
I found a 9" rearend to rebuild, ordered a true trac locker, 3.89 gears, to go along with the AOD and 5.0, I have already put in.
what do you think about this gear set up?
and will I have to cut down the Drive shaft again?
65Rocky is offline
Old 05-05-2009, 03:40 PM
eZ
eZ's Avatar
youll just have to measure the 2 different rears but i think you should be ok. Im running a 5.0, aod, 9'' detriot locker, and 4.11's. I love the setup and the od on the aod is great. get a wratchet shifter makes the aod a lot of fun.
eZ is offline
Old 05-05-2009, 09:37 PM
gothand
gothand's Avatar
If you're looking for opinions, I'm thinking you'd be a bit happier with 3:50-ish gears, especially if you have smaller diameter tires. I'm not positive about the driveshaft length, but I'd venture to guess that you're going to have to.
gothand is offline
Old 05-07-2009, 02:48 PM
65Rocky
65Rocky's Avatar
OK 3.89 then.
65Rocky is offline
Old 05-12-2009, 11:55 AM
65Rocky
65Rocky's Avatar
Got it back together, the 3.89 True lock, 9" AOD, not the outcome I was hoping for should of went with the 4.11
65Rocky is offline
Old 05-12-2009, 01:56 PM
2+2GT
2+2GT's Avatar
If you have gone from an 8" to a 9", the shaft will have to be shortened, assuming it was a proper length for the 8". The 9" is larger, so the front sticks out more, so the drive shaft has to be shorter.
2+2GT is offline
Old 05-12-2009, 02:44 PM
eZ
eZ's Avatar
I went with the 4.11's and am very happy. I find gears to be like a girl getting implants, they always wish they had gone bigger!
eZ is offline
67LimeCoupe
09-30-2015 04:46 PM
67LimeCoupe
09-21-2015 06:34 PM
67LimeCoupe
09-02-2015 08:02 AM
jhutch
08-19-2004 05:57 PM
S_man_9
08-13-2004 12:32 PM
Quick Reply: 8" to 9" rearend
