Back from the dyno :)
Hi friends,
I am back from the dyno and here are the results! The two first runs showed 240 and 241 rwhp and indicated that I was running too rich (AF between 10.5 and 11.5 in the 4000 -> 5500 RPM range). Then changed the jets and played with the timing, it went to 256. They were convinced that they could get more and noticed that my air filter was small / bad quality. They changed it to a 3" (as opposed to the 2" I had) and it went to 269 rwhp which is the final score They double checked and go the same result after 5 minutes.
I had a great time and I guess I can admit now that my 289 is really healthy! For those interested, everything is in my signature.
Not bad
Here is a quick video: http://www.youtube.com/watch?v=hxJj4TqoxoM
Thanks!
Not bad
Thanks!
Hi Remi,
that's great news. you are at about 75% of what desktop dyno predicted for engine. Since that is not BHP and you measure rear wheels it seems quite accurate to me.
Although the desktop dyno predicted peak torque at 4250, not 4050. What was the rpm @ peak HP? 5500rpm?
Can you post the resultsheet and I'll upload the desktop dyno for your car so we can compare the difference. I'd be interested to see that on real life example
What I find mad is that everyone had it in the same 20+-HP area :-)
.... and of course congratulations!
Kalli
Kalli
yes leaning it to 13.0-13.8 could yield even more, so your making over 1hp per cube fwhp thats a strong but mild mannered 289, you should pull really good mpg's hwy as well.....good job! The combo works well.......get rid of those "slowmasters" and I would bet you could pick up another 15hp with good muffs.
