Do stock exhaust manifolds really cut 60 hp?
or is that a flaw in desktop dyno
with my almost bone stock 289 with factory exhaust it shows 225 hp @ 5300
but when i click shorty headers with mufflers it goes to 280 @ 5700
is there that much to gain with headers?
i have long tubes and a full 2.5 mandrel bent exhaust with an x pipe, so i probably lost power due to back pressure. but even so i doubt you'll gain 60 with just headers, but as you increase your engine capacity exhaust is a corner stone to performance.
Maybe if you have an engine already making 600hp you might find 60 by going to headers from a stock manifold.
Realistically you're stock 289 is like 185hp and with headers would be like....188? Maybe 190 on a really good day.
The stock manifolds are pretty pitiful. However, they are a good match to the horribly small exhaust ports in the stock iron heads, even the 289HP heads. The 289HP manifolds are much better, and if you port-matched your heads to 289HP manifolds, you'd see significant gains. If you have an upgrade cam, it would be even better, because the potential gains from your cam are being strangled by the ports. No matter what headers or exhaust you use, these ports are killing your performance.
