rear springs: reverse eye? standard eye?
please help. 1967 coupe, 302 manual
looking for a stock ride height but real firm spring rate/firm ride.
what should i order, (mustang plus grad a track kit)
they have standard eye, reverse eye and mid eye.
I'd recommend 4.5 leaf. 5 leaf springs are very stiff, and better suited for track use.
OE ride height would be standard eye. Keep in mind, the OE ride height is rather tall, and if you still have original springs you're probably sitting quite a bit below that.
+1 I have 5leaf mideye. It's not stock height but looks the business. The wheel matches nicely into the arch. looking good I find. and hell yes ya. that's stiff. If I ever had to do it again I'd get the 4.5 leafs. Seller in Germany just didn't have them in stock ...
so reverse eye and mid eye are lower? id rather be at stock hieght. since the plans are to put 17s on eventually. but id rather be to high then rub.
Standard eye is stock ride height, mid eye is about 1" lower and reverse eye is around 1.5-1.75" lower. 5 leaf is gonna be freaking STIFF. 4.5 leaf with a good shock can still be rather stiff. I wouldn't run 5 or more unless it were a track only road racer.
Leaf springs aren't going to affect header clearance.
If you're planning on changing the front springs, get the mid-eye leafs for now. 1" drop springs in the front will level out the suspension down the road.
