Drivetrain
#21
Do you guys think that running the larger gears and bigger v8 components would actually be smart with the i6 setup? I know he now has the choice of more gear selections but with the increase drag from the larger components will he come out ahead?
I have never heard of this being done before..is there a good reason why?
-Gun
-Gun
I will change my prior answer and defer to Kalli's expertise on the u-joint sizing.
We used the I-6 driveshaft behind the 408W, but I had the ends changed to 1350 on the rear for the 9" rear, and then the front to a 1310 style for the Tremec TKO.
It would make more sense and be cheaper to just buy a new shaft if changing both joints at the same time.
#24
http://mustangsunlimited.com/itemdy0...atKey=EMUSTANG
Is this the one I need. My driveshaft was to small and these are too. So what u-joint do I need for the driveshaft to make it fit the 8"?
#25
You might be able to buy a "hybrid" U-joint at a driveline shop.
It is big on one end and small on the other...
If you can figure out what series yokes you have it MIGHT be a simple matter of getting a conversion joint.
The BEST fix is to have the shaft modified to have the right yoke, should cost about a Franklin...
Kalli probably has it right 1210 shaft, 1310 rear...
I did a quick internet search for "conversion u-joints", I did not find any 1210/1310 hybrids.
#27
even if there was, this would be something you wouldn't want as the difference between the 2 axis is nearly and inch. There has been claims that tehre are conversion u-joints from 1210 to 1310, but noone ever came up with one when asked.
Depending if the driveshaft is a 1250, and the yoke 1310 you will find a hybrid in a syhop that'll fit you.
If you pass measurements as above (cup dias and length) of driveshaft and yoke I can tell you what you'll need.
edit: those u-bolts you posted should fit a stock V8 rear yoke. even if cap is 1-1/16 it'll do
#30
