Dropped a nut into the intake...
#23
Well, if you really don't want to pull the manifold, try removing the valve covers, and taking all the tension off all the valves so it wont go down in the cylinder, THEN use compressed air to find it.
Overall your in a tough spot =/ you could get lucky and get it out easily, if not it may require a good bit of work.
#24
Why is everyone acting like R&R an intake is brain surgery. A couple hours a new set of gaskets and a torque wrench and its done. It sounds like he has already tried and tried to fish it out. I would not risk damaging the engine or risk it getting into a cylinder because then he is worse off.
#27
You could bend a valve or nick a valve or seat that way.
#28
thanks a lot or all these ideas! i have tried a shop vac but the problem with that is at the end of the one i used the plastic part wont let me get it into the actual manifold.i gues ill try with the magnet some more today, if not im just gonna pull the intake. i feel like i made such a retarded mystake... how much would the new gaskets and silicone cost, could i reuse the coolant?
#30
