tires and rims
tires and rims
I have a 65 coupe w/ a 289 in it.
Really good stock tires i think like 14s
the question should i buy bigger rims and tires for it. I am about to take it on a 10 hour trip and not sure if those tires are good enough.
I am putting new rims already just not sure on a size that would be good.
I second the 17" because in future if you ever decide to get disc brakes upfront you can run the larger rotors + the benefit of having better tire choices. 17" wheels wont close any doors on you and allow for expandability in the future.
-Gun
-Gun
I wish I could recommend a 15" tire, but unless you're willing to settle for mediocrity that's round/black/holds air there just isn't much. BFG g-Force Sports may be the best of what's left in the small wheel street tire sizes, and they simply can't compare to any of the better offerings in 17". Not even as good as some of the 15" tire makes/models that have gone out of production, if my own direct personal experience is worth anything.
I don't like being pushed up-size any more than some of the other respondents here, as I have at least two cars and a possible project or two that all started life with 15" or smaller. But it's either eat at the 17" dinner table or settle for the scraps that fell on the floor from the 15" high chair.
Norm
Norm
Haha
Norm now that we are on the subject. I might as well ask a question I have had for a long time. I really plan to switch to 17" here in a while (a year maybe) The only thing I am concerned about is messing up my ride height.
Most stock mustangs have enough ground clearance to rival an s10 truck...I have worked on suspension enough to avoid this. Right now front height is 23" and rear is 24" measured from ground to fender arc apex.
Front tire is 195/60 14
Rear tire is 215/70 14
What would have to be done to maintain ride height with a 17" wheel? I'm guessing shelby drop up font and 50 or less series front tires?
Thanks
-Gun
Thanks
-Gun
195/60-14 is a little undersize anyway. The first 17" size that gets closer load capacity-wise without getting "huge" is 215/45, and you probably should get one that claims "XL", or extended load. You'll still need to run higher inflation pressures than the door sticker or owner manual calls for.
For the rear, 225/50-17 is about the same OD as what you have now. As it happens, both sizes are available in the Goodyear Eagle F1 GS-D3 lineup, although since they're directional you wouldn't even be able to rotate them side to side without breaking them down, flipping them inside to outside on the rims, and rebalancing.
Yes, I know the 215/45-17 is an inch or so taller than your current front tire . . .
Norm
Norm
