Vacuum port on Holley 4160?? - Page 2 - MustangForums.com
Old 05-25-2009, 07:22 PM   #11
19stang66
Yes you are correct in saying that my engine ran like sh*t. But that is also due to the fact that the rubber fuel line was kinked before the fuel pump
So what's the difference between using the bottom nipple for "full manifold vacuum" or the upper nipple for "ported manifold vacuum"??
19stang66 is offline   Reply With Quote
Old 03-29-2014, 05:48 PM   #12
my68ride
Default vacuum port at base of carb
The vacuum line from your automatic transmission would go there
my68ride is offline   Reply With Quote
Old 03-30-2014, 11:24 AM   #13
2+2GT
Well, It could go there, but the factory connection for the trans was the rear manifold fitting. That carb fitting is very convenient for connecting the manifold vacuum part of the Distributor Vacuum Control circuit, but again, since the 4160 was not a factory installation, Ford connected it elsewhere.
For example, the "red stripe" hose could be connected to that port-
2+2GT is offline   Reply With Quote
Old 03-30-2014, 06:33 PM   #14
barnett468
Quote:
This is a complicated and sometimes contentious issue, lol.
The bottom front fitting is full time manifold vacuum. Do NOT use it for your distributor or trans.
The top side fitting has supposed to have virtually 0, nada, zilch vacuum at idle. I has vacuum just a hair above idle.
If it has vacuum at idle you have a problem. Tell us and we can tell you how to easily fix it.
barnett468 is offline   Reply With Quote
Old 03-31-2014, 01:47 AM   #15
Gun Jam
Moderator
Gun Jam's Avatar
Whats ****ing complicated is why my68ride would reply to a 6 year old thread...yeah its great you want to help this guy but im not sure how this even happend....
-Gun
Gun Jam is online now   Reply With Quote
Old 03-31-2014, 03:00 AM   #16
barnett468
Quote:
-Gun
Ahhh, ha, ha. That's funny. I didn't see that.
Old 03-31-2014, 10:09 AM   #17
my68ride
Default 6 year old thread
I answered a 6 year old thread??? I was looking for a Holley carb. part and I guess that question popped up. Stupid computers! I changed my 289 for a 302 with aftermarket intake manifold and Carb, so that is where I had to connect my trans vacuum......didn't know it was a 6 year old thread and don't even know how I ended up on Mustang Forms.
Old 03-31-2014, 12:29 PM   #18
Gun Jam
Moderator
Gun Jam's Avatar
For whats its worth there is somewhat of debate between running a vac advance dizzy off of full manifold vac OR ported vac.
distributor manufactures will always tell you to run ported vac.
However there is a following of individuals that have good success running full manifold vac on there distributors.
I have tried both and I found that running full manifold vac caused the exhaust to smell rich and unburned despite allowing me to run idle mix a full air fuel ratio point higher than I could with ported vac. Im thinking this is due to reduced exhaust gas temps in the headers not fully burning off the exhaust.
-Gun
Old 04-02-2014, 01:00 AM   #19
barnett468
you might know this.
the ported and manifold vac are exactly the same above around 1/8th throttle opening.
there is basically no ignition advance from the vacuum under hard acceleration.
the sole purpose of dist vac is to improve mileage.
in california you must have the original smog equipment in place even if your car passes the tailpipe test.
on the old cars they check the emissions at idle and cruise but only use one reading.
calif smog is stupid, lol.
Intake manifold replacement Dokilar 4.6L (1996-2004 Modular) Mustang 15 10-16-2015 08:13 PM
1994-1995 ODBII Port Urambo Tauro 5.0L (1979-1995) Mustang 6 10-05-2015 09:37 PM
So who wins uedlose The Racers Bench 4 10-01-2015 08:31 PM
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 09:01 AM
Please help! 10 Check engine codes mrtrodonet V6 (1994-2004) Mustangs 1 09-29-2015 11:13 AM
4160, 65, carburetor, defined, diagram, distributor, full, holley, lines, manifold, mustang, port, ported, ports, timed, tuning, vaccum, vacum, vacuum
