Linear or progressive, rate for coil springs? 70 fb
Old 05-29-2009, 09:02 AM
BigMan52
BigMan52's Avatar
Default Linear or progressive, rate for coil springs? 70 fb
Ok, so I can't seem to find this with a search. I've got a 1970 fastback with a 351C, and I'm looking to replace the front springs. I'll get a 1" drop, but I can't decide on 620 lb vs 540 lb or linear vs progressive.
The car will be a daily driver when its done, but I don't want to completely sacrifice performance.
Any experiences or opinions?
Cheers.
BigMan52 is offline
Old 05-29-2009, 10:46 AM
67mustang302
67mustang302's Avatar
Don't get progressive, use a linear.
540 if you want some performance and a decent ride, 620 if you want more performance with a stiffer ride. 540 is still quite a bit stiffer than factory springs, that were like 270.
67mustang302 is offline
Old 05-29-2009, 09:43 PM
htwheelz67
htwheelz67's Avatar
in a 70 620's will be a better performance/ride quality especially if you install roller perches, I have cut 620's, roler perches and konis on my 67 vert and it rides and handles great.
htwheelz67 is offline
Old 05-29-2009, 09:44 PM
htwheelz67
htwheelz67's Avatar
Default springs
Old 05-29-2009, 09:59 PM
Starfury
Starfury's Avatar
I really doubt it rides 'great' with cut 620's and konis. My '67 with 540's, roller peches, and edelbrock shocks ride ok. Not fantastic on bumpy roads, but they handle great. I wouldn't want 620's where I live.
Starfury is offline
Old 05-30-2009, 12:41 AM
Adrenolin
Adrenolin's Avatar
540 linear is your best choice.
Adrenolin is offline
Old 05-30-2009, 01:53 AM
cprstreetmachines
cprstreetmachines's Avatar
A 351C is a heavy beast. JUUUUST did one not two days ago. 750 springs and KYB gas -a-just and almost a little on the soft side compared to a 289-302 with 620 same shock setup. If you don't want to sacrifice performance, you'll be happy with the same. Perfect for a performance oriented daily driver. We also did a shelby drop with roller perches. Handles about as good as any big block can handle without going full tilt.
cprstreetmachines is offline
Old 06-02-2009, 11:41 AM
BigMan52
BigMan52's Avatar
Thanks, guys. I think I'll go with linear 620's and roller perches and see how she goes from there
BigMan52 is offline
firehorse02
11-16-2015 11:28 AM
mungodrums
09-28-2015 10:54 PM
09-27-2015 03:16 PM
09-25-2015 09:06 AM
Quick Reply: Linear or progressive, rate for coil springs? 70 fb
