Can you fit a 460 Big block into a 67 mustang fastback?
Old 05-29-2009, 06:11 PM
grod297
grod297's Avatar
Default Can you fit a 460 Big block into a 67 mustang fastback?
How easy or difficult would it be to fit a 460 big block into a 67 fastback
Any suggestions?
Thanks
grod297 is offline
Old 05-29-2009, 06:45 PM
Waffles
Waffles's Avatar
Location: Detroit; where the weak are killed and eaten.
It could happen, but why?
Waffles is offline
Old 05-29-2009, 06:59 PM
cmanf
cmanf's Avatar
You can fit a 460 in my 66 but i went with a 347.
cmanf is offline
Old 05-29-2009, 09:09 PM
grod297
grod297's Avatar
I wanted effortless torque with a naturally aspirated easy cam .. motor
grod297 is offline
Old 05-29-2009, 10:06 PM
67mustang302
67mustang302's Avatar
Then build a 347. You can still make more torque with a 347 in an "effortless" engine than your suspension will hold, unless you spend about $8,000 to upgrade your suspension.
Or if you want even less effort, build a 408, a 351 block will fit a lot easier than a 460.
67mustang302 is offline
Old 05-29-2009, 10:21 PM
EZFEED
EZFEED's Avatar
I cant imagine how nose heavy it would be with that in there.......
EZFEED is offline
Old 05-29-2009, 10:28 PM
67mustang302
Very, and it would steer like ***. That's the exact problem the 427 Cobras had, fast as hell in a straight line, understeer like a runaway sled(because that's what they were!)
Old 05-29-2009, 11:29 PM
andrewmp6
andrewmp6's Avatar
a 66 no big block will fit with out cutting the shock towers out.67-73 both the fe and 385 will bolt in.I would build a small block its cheaper.
andrewmp6 is offline
Old 05-29-2009, 11:43 PM
Starfury
Starfury's Avatar
I don't believe the 385 motors will fit in a 67-70 without a little bit of shock tower massaging. They're very wide, almost as wide as mod motors.
Starfury is offline
Old 05-30-2009, 03:19 AM
andrewmp6
andrewmp6's Avatar
No they bolt right in on 67-70 tarafield i think is his name on here he has a 429 in a 68 its a tight fit but he didn't have to cut anything but lose the cross member for oil pan room.The fe a 385 are almost the same size the fe is wider tho.
Quick Reply: Can you fit a 460 Big block into a 67 mustang fastback?
