Resistor wire and coil voltage
After having ignition problems, I replaced the original resistor wire in our '67.
Runs okay now, but wonder if it is working right.
Voltage at coil with ignition switch in run position, engine off is 7 volts.
With engine running, it reads 12 volts.
I thought the resistor wire was supposed to reduce the voltage to 6-9 volts while running.
Is this a problem? Will it burn up points and coil?
Thanks.
Thanks.
Thanks.
Thanks.
The coil should have 12V during cranking through the bypass post "I" post on the starter solenoid. After the cranking stops, you should get about 9 volts at the coil from the resistor wire b/c the I terminal goes dead after cranking stops. Like mentioned above, points will not like getting full voltage all the time.
jwog666
12-27-2021 08:09 PM
