Rebuilt control valve, too much play in ball stud?
Just returned from the alignment shop where I was told there was too much play in the ball stud where the pitman arm connects to align the car ('67 Coupe, power steering) properly. They pulled me into the bay and while one turned on the wheel the other showed be how much wiggle there was in the ball stud area (the castle nut is tight, it's the ball stud and slider that has too much play). There's about a 1/4 to half in of movement when the car is off the you're rocking the steering wheel. The valve was rebuilt by yours truly so there is a decent chance I did something wrong.
I followed the directions to a tee and laid everything out in the order it came out and replaced in the same order.
Any body have any experience with this that could give some guidance on where to start looking. Obviously the valve needs to come apart, but what should I be looking for specifically?
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
Good info guys, thanks. I'll be sure to ask some questions next time before I bring the car in.
